Hello all,
Recently I’ve encountered a performance issue with a script I’m running that checks for tag changes on 4800 different tags. On occasion, this script has to run 4800 times in double succession. Essentially triggering a tag change script 9600 times with ~3.5 seconds in between the first set of 4800 triggering and the second set of 4800…
I had to increase the heap size min and max to 2048/4096 in the config file in order for the script to not completely overload the Gateway. For some clarity, here’s the script below:
index = int(str(event.tagPath.itemName).split("_")[-1])
column = str(event.tagPath).split("/")[1]
currentValues = system.tag.read("[default]ExtInterfaceTags/loadedData").value
try:
newValues = system.dataset.setValue(currentValues, index - 1, column, newValue.value)
system.tag.writeSynchronous("[default]ExtInterfaceTags/loadedData", newValues)
except IndexError:
system.util.getLogger("Value Change Debug").info("%s changed, trying to write to dataset index %s" % (event.tagPath, index))
This script’s purpose is to update a dataset that is binded to a Table being used to populate results from a sequenced process. The tag change script is no issue when running the normal process of updating the values from 0 to the result value, as it is only a few tags changing at a time every 5+ seconds, but in order to clear the table, we have to populate all 600 rows with numbers, then set them to zero.
So, I guess my questions are:
1.) How can I make the script process faster? I know this may not be possible as there aren’t really any lines of code to remove to speed it up.
2.) How do I stop the connection from being “overloaded”? I get around 3 error messages on a client tag that is set to be a heartbeat saying that it has timed out. I have noticed the heap never goes much above 2.2 gbs, so I wouldn’t imagine this is the problem.
3.) What alternatives do I have?
-Maybe an alternative method to clearing the table?
-I don’t have the reporting module or anything to allow SQL.
-Is there a way to control visibility of rows based on an index of rows? This would essentially let me remove the
populating the fields with 2 sets of values and hard code the table if there is a way to do that.
Whatever suggestions any of you have, would be greatly appreciated!
