Gateway Tags Logging to Historian
Hi Guys,
I have set store history for various gateway tags for monitoring and alarming (such as cpu/memory utilization).
When I drag these tags into an Easy Chart, it appears as though nothing is being logged to the historian (everything says 0 when I can see the realtime values are none 0)…
Can we not log gateway tags to the historian?
Ignition 7.9.9
I tried it out and had the same issue…
Easy way out is to create a new expression tag on your default tag provider which refer to the gateway tag. Then configure historian on that expression tag.
Tried it and it works on my system :stuck_out_tongue:
I believe this is a bug that’s fixed in 7.9.10 or .11.
Probably 7.9.11… my system is 7.9.10 and has same behavior
Thanks guys, I will be upgrading our servers to V8 sometime in the next few weeks so will wait until then!
