Dear All,
Please anyone guide me for reading the tag instance name from tag browser using the gateway timer event script (every 1 second) and has to run the named query for inserting the collected tag instances name to the table.
please guide me if anybody have idea about this.
Thanks in Advance
A tag browser in a Vision client? A gateway script will not have any access to the components of a client. Perhaps you need a client timer event script? Or perhaps a timer component on the window that contains the tag browser component.
I have more than 1000 of tags under one Tag folder in Tag Browser, I want to update the Tag Names into the SQL table every 10 seconds. Now I am running the script inside the perspective view using timer trigger. But instead of that I want to run the same script in Gateway Scope.
Because If I running the script inside my perspective session, when no.of session will increase, every session will run the script every 10 seconds. Am I right ?. To avoid these kind of execution I want to run the same script in gateway scope. By this way I can run the script only once at a time, even If my No.of session Increased.
You are right
Typical example where you want to run the operation in gateway scope
It will probably perform better also.
Thank you for your replies.
I have completed this with the use of System Functions in Gateway Timer event Script.
