Hello, I have a project where I am using a Gateway Timer script to trigger a session handler, that triggers a view handler that calls some custom methods. However, I'm checking my logs on the gateway and I'm not seeing the session handler sending the params to the view anymore.
Setting the session_id in the startup:
Gateway Script:
# Timer Script - every 2 minutes per project (MF1, MF2, etc.)
# Created by AMS2 - Updated with active session check and writeAsync
logger = system.util.getLogger("ShiftTimer")
try:
hmi_ip = '10.147.10.120'
sessions = system.perspective.getSessionInfo()
session_id = None
for s in sessions:
logger.info("Session found: ID {}, IP {}".format(s["id"], s["clientAddress"]))
if s["clientAddress"] == hmi_ip:
session_id = s["id"]
break # Stop at first match
if session_id is None:
logger.warn("No active session found from IP: {}".format(hmi_ip))
else:
# Read tags only if session is valid
machine = system.tag.readBlocking(["[OMA]Pipe/MF1/job_data/MachineID"])[0].value
machine_name = system.tag.readBlocking(["[OMA]Pipe/MF1/job_data/MachineDescription"])[0].value
# Query shift data
ds = system.db.runNamedQuery("MF1_Dashboard", "shift/GetShiftByMachine", {"machine_id": machine})
pyDS = system.dataset.toPyDataSet(ds)
current_start_time_dt = pyDS[0]["start_time"] if pyDS.getRowCount() > 0 else None
current_end_time_dt = pyDS[0]["end_time"] if pyDS.getRowCount() > 0 else None
current_shift = pyDS[0]["shift"] if pyDS.getRowCount() > 0 else None
old_start_time_dt = pyDS[1]["start_time"] if pyDS.getRowCount() > 1 else None
previous_end_time_dt = pyDS[1]["end_time"] if pyDS.getRowCount() > 1 else None
previous_shift = pyDS[1]["shift"] if pyDS.getRowCount() > 1 else None
# Async write
system.tag.writeAsync([
"[OMA]Pipe/MF1/Shift_Info/StartTime",
"[OMA]Pipe/MF1/Shift_Info/EndTime",
"[OMA]Pipe/MF1/Shift_Info/Shift",
"[OMA]Pipe/MF1/Shift_Info/old_start_time_dt",
"[OMA]Pipe/MF1/Shift_Info/old_end_time_dt",
"[OMA]Pipe/MF1/Shift_Info/last_shift_processed"
current_start_time_dt,
current_end_time_dt,
current_shift,
old_start_time_dt,
previous_end_time_dt,
previous_shift
# Send to session
system.perspective.sendMessage(
project="MF1_Dashboard",
messageType="reset_tags",
scope="session",
sessionId=session_id,
payload={
"machine": machine,
"machine_name": machine_name,
"old_start_time_dt": old_start_time_dt,
"trigger_ip": hmi_ip
logger.info("Message sent to session {} for machine {}".format(session_id, machine_name))
except Exception as e:
logger.error("Timer script failed: {}".format(e))
Session Handler:
def handleMessage(session, payload):
#Session Message Handler for "reset_tags"
logger = system.util.getLogger("Shift Timer")
machine = payload["machine"]
machine_name = payload["machine_name"]
old_start_time_dt = payload["old_start_time_dt"]
trigger_ip = payload.get("trigger_ip", "unknown")
logger.info("Reset tags message received for {} from IP {}".format(machine_name, trigger_ip))
# Forward payload to view
scope="view",
payload={
"machine": machine,
"trigger_ip": trigger_ip
logger.info("Forwarded reset_tags message to view for {}".format(machine_name))
View:
def onMessageReceived(self, payload):
system.util.getLogger("ResetTagsHandler").info("Handler triggered with:{}".format(payload))
logger = system.util.getLogger("Root Component Reset Tags Handler")
logger.info("Reset requested from IP: {}".format(trigger_ip))
#calling reset method
self.getChild("Header").reset_tags(machine, machine_name, old_start_time_dt, trigger_ip)
