i’m working with gateway event, it seems that the event i generated are not showing in status > gateway scripts.
planning to run a script every hour.
below example is just for testing thats why its set to 1000ms.
Hi marcg, did you solve this issue?
Hi ,
i have also facing the issue is their any thing i want to do .
every time i want to restart the server for that
Did you find what the issue was? Have same issue
Scripts only show in that page if they are running. Anything that executes quickly (as even scripts should) is only randomly going to show there (when the page self-refresh exactly hits when the script runs).
If you are trying to determine if your script is running at all, put a logging statement at its start.
