Hello everyone,
I’m running some timer scripts in order to get some information from a file.asc, it used to work properly but now it seems that the script is not working in this timer script. If I execute manually in the script console it works. I also tried another print in logs script for testing and works.
It is as if the code was empty. This is my script code.
import time
import threading
import os
import glob
def getFile():
import os
import os.path
import glob
import system
machine = "MDR 1"
machineFolder = "MDR1"
directory = glob.glob('E:\\' + machineFolder + '\\*.asc')
if len(directory):
	newFile = max(directory, key =os.path.getctime)
	previousFile = str(system.tag.read("File Directory/%s" % (machine)).value)
	if str(previousFile) != str(newFile):
		file = open(newFile, "r")
		data = [line for line in file.readlines()]
		file.close()
		system.tag.write("File Directory/%s" % (machine), newFile )
		logger = system.util.getLogger("LabTest File Read-%s" %(machine))
		logger.info('New File Available. Parsing file - %s '%(newFile))
		return data, machine
	else:
		print 'File is processed !'
		return None, None
else:
	print "Folder has no files"
	return None, None
data, machine = getFile()
if data :
ret = project.LabTesting.parseAlphaFile(data, machine)
I share with you the thread dumps
Daemon Thread [gateway-script-dedicated-timer-[LabTesting/MDR 1]] id=14689, (TIMED_WAITING)
waiting for: java.util.TaskQueue@57aac92
java.lang.Object.wait(Native Method)
java.util.TimerThread.mainLoop(Unknown Source)
java.util.TimerThread.run(Unknown Source)
Daemon Thread [gateway-script-dedicated-timer-[LabTesting/MDR 2]] id=14687, (TIMED_WAITING)
waiting for: java.util.TaskQueue@4d46a8d8
Daemon Thread [gateway-script-dedicated-timer-[LabTesting/MV 1]] id=14692, (TIMED_WAITING)
waiting for: java.util.TaskQueue@5d2ca7cb
I hope you can help me out.
Thanks.
