I want to make a gateway timer script in a base project, but that project is inherited by others. I don't want the gateway timer script to be repeated in all of the children projects (at least I don't want it to run from in all the children projects). I just need it to run in one instance. Is there a nice way to make that happen other than only putting the timer script in one child project, or overriding all of the children projects I don't want the timer script in?
If you're on 8.1, no.
In 8.3 you have an option to "migrate" your resources to a 'split' format, where they're individually overridable/inheritable (literally one resource per timer script, for instance) and individually enable-able.
Good to know!
I am currently on 8.1 yes...
You could add a kill function right at the start of the script that checks the project name it's being run from, and if it isn't the one you want, exit.
This a really bad idea in general, and will be a nightmare to maintain even with the finer granularity in v8.3.
Just don't. Define your gateway event(s) in the appropriate leaf project.
I recommend an inheritance architecture something like this:
