Hi everyone,
I’m working on a server running Ignition 7.9.2, i’m having issues with the time diplayed by the gateway. All the 3 proyects running in theese gateway are configured to use the Gateway timezone, but the gateway is one hour ahead the server time. I’m triying to figure out where the problem is but i can’t find somethig that show me why the gateway doessnt have the same time than the server. I have tried restarting the gateway but nothing happens and if i change the server time, the gateway also change but allways one hour ahead.
Any suggestion???
Thanks!!
It seems Chile has undergone some DST changes in recent years. You may need a more recent version of Java with this updated information.
Thanks Kevin, the server is running 8u131, i’ll try to update java to the last versión soon as possible.
Stay on Java 8 though. Just the latest version of 8.
Thanks Kevin, the problem was solved with Java 8u221
