Gateway upgrade stuck in between
I was upgrading ignition version from 8.3.5 nightly to 8.3.6 stable version but while starting gateway it got stuck in "gateway starting" mode. Also attaching wrapper log.
wrapper - Copy.log (1.8 MB)
What kind of upgrade / install was this? With the installer? Zip files?
E [C.BasicExecutionEngine        ] [15:29:29.139]: One-shot task com.inductiveautomation.ignition.gateway.IgnitionGateway$$Lambda$745/0x0000000080436718@7150ad50 threw uncaught exception.
java.lang.NoClassDefFoundError: com/inductiveautomation/ignition/common/tags/rpc/TagProviderRpcUtil
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.createRpcImplementation(IgnitionGateway.java:3632)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1291)
	at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:367)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:807)
	at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$1(IgnitionGateway.java:720)
	at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:557)
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.ignition.common.tags.rpc.TagProviderRpcUtil
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	... 12 common frames omitted
with the installer.
