Gateway webinterface stopped responded?
Using 7.5.5, about to be upgraded to 7.5.14.
Recently last week the web 192.168.142.80:8088 stopped being responsive. On the computer that hosts Ignition, localhost:8088 the webpage shows up but for other computers on the network it does not.
I tried turning off all firewalls as a test to see if that would help but it did not.
In chrome it seems to redirect a few times from the ip to main, web, then home and then it stalls out -
I did a wireshark capture of my attempt to connect -
wsCapture.pcapng (1.6 MB)
Not sure what else to try or do here. We are upgrading to 7.5.14 and potentially later if license allows now in case this is an old bug that was resolved. Any other things to try or look at?
Was a bad port in a switch that was making connections way too intermittent. This is why you should always check layer 1 first haha
