Gateway Webpage goes away after inital setup
I originally had ignition set on this machine and licensed as a back up. It shutdown and wouldn’t start back up, just kept faulting. So I uninstalled. Removed the install directory and reinstalled. I can get to the startup page. Select the version and then set up an admin user and pw. As soon as I do the gateway webpage goes away. I have uninstalled and reinstalled a couple of time. Not sure what is going on? Its still listening on 8088 and not faulted after getting past setup screen.
Ubuntu 24.04.3 LTS
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [g.PersistentRecordIdpAdapterConfigService] [20:57:50.973]: Started up in 3 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [g.PersistentRecordIdpAdapterMetricsService] [20:57:50.973]: Started up in 0 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [g.IdpAdapterManager           ] [20:57:50.973]: Started up in 0 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [g.InternalDatabaseRememberedSubjects] [20:57:50.975]: Started up in 1 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [g.OIDCProviderManager         ] [20:57:50.975]: Started up in 2 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [t.m.provider                  ] [20:57:50.978]: Tag provider initialized. Starting to load tags... provider=System
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [t.m.provider                  ] [20:57:50.989]: Complete tag loading in 10 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [t.manager                     ] [20:57:50.998]: Instantiating provider 'edge' of type 'STANDARD'
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [t.s.internaljson              ] [20:57:51.055]: Redundancy version token not set for provider 'edge', will initialize to system version. provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [t.m.provider                  ] [20:57:51.064]: Tag provider initialized. Starting to load tags... provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [P.InternalDatabase            ] [20:57:51.065]: Looking for existing internal database "references.idb"... provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [P.InternalDatabase            ] [20:57:51.065]: ... no files found, will create. provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [P.InternalDatabase            ] [20:57:51.065]: Creating new internal database "references.idb". provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [P.InternalDatabase            ] [20:57:51.073]: internal database "references.idb" started up successfully. provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [c.i.i.g.t.r.DbTagReferenceStore] [20:57:51.074]: Tag Trace store attempting to create tables. provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [c.i.i.g.t.r.DbTagReferenceStore] [20:57:51.082]: Tag Trace store successfully created tables. provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [c.i.i.g.t.r.DbTagReferenceStore] [20:57:51.082]: Tag Trace store started. provider=edge
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [t.m.provider                  ] [20:57:51.087]: Complete tag loading in 4 ms
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [i.UserSourceManager           ] [20:57:51.138]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [g.InternalDatabaseManager     ] [20:57:51.183]: Upgrading schema for module ""
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [A.S.StorageManager            ] [20:57:51.208]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [A.N.NotificationManager       ] [20:57:51.226]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [a.J.LocalAlarmJournal         ] [20:57:51.310]: Alarm journal initialized successfully.
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [a.J.LocalAlarmJournal         ] [20:57:51.310]: Alarm journal system started.
INFO   | jvm 1    | 2025/12/04 20:57:51 | I [ImageManager                  ] [20:57:51.333]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:54 | W [g.LicenseManager              ] [20:57:54.002]: Could not read license from HASP key. Driver not found
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [ImageManager                  ] [20:57:57.181]: Imported 352 builtin images in 5846ms
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [Project                       ] [20:57:57.195]: Starting project: Edge project=Edge
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [g.AuthTokenManager            ] [20:57:57.375]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [DesignerAuthTokenRecords      ] [20:57:57.375]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [DesignerAuthTokenRecords      ] [20:57:57.380]: Startup completed in 4 ms
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [ClientAuthTokenRecords        ] [20:57:57.380]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [ClientAuthTokenRecords        ] [20:57:57.380]: Startup completed in 0 ms
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [g.AuthTokenManager            ] [20:57:57.381]: Startup complete in 5 ms
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [SessionManager                ] [20:57:57.381]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [AutomaticThreadDumpManager    ] [20:57:57.383]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [c.i.i.g.m.MulticastScheduler  ] [20:57:57.386]: Registered MulticastScheduler on multicast address: 231.1.1.1 using send port 4445 and receive port 4446
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [g.ClientFallbackController    ] [20:57:57.388]: Fallback Socket Controller starting.
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [IgnitionGateway               ] [20:57:57.581]: Platform module services initialized.
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [G.Manager                     ] [20:57:57.614]: WSChannel manager started.
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [m.M.Routing                   ] [20:57:57.616]: Setting max proxy route depth = 0
INFO   | jvm 1    | 2025/12/04 20:57:57 | W [g.g.WSChannelManager          ] [20:57:57.643]: Require Two-Way Auth setting is disabled, rendering Gateway Network connections insecure. It is strongly recommende>
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [g.g.WSChannelManager          ] [20:57:57.671]: GAN channel manager started successfully.
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [g.ModuleManager               ] [20:57:57.700]: Starting up...
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [IgnitionGateway               ] [20:57:57.719]: Ignition[state=STARTING] ContextState = RUNNING
INFO   | jvm 1    | 2025/12/04 20:57:57 | I [IgnitionGateway               ] [20:57:57.719]: Gateway started in 14 seconds.
What does this mean, exactly?
You're looking at a browser tab (showing some kind of loading indicator, presumably, while the gateway starts up) - and then what? The browser tab closes? The screen is empty? What URL is loaded in the web browser? What happens if you try to navigate to the gateway webpage in a new tab? Are there any errors in the browser console? Etc.
Your snippet of log shows a totally normal startup.
