I attempted to create a gateway event message so I could send a message and run scripts on the gateway scope through the designer. Here is the gateway script:
However, when testing this in the script console I got the below error. Is this just not possible to do?
edit: would probably be helpful to include what I have in the script console
version: Ignition 8.1.48
Java Traceback:
File "<input>", line 4, in <module>
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:965)
at com.inductiveautomation.ignition.client.script.DesignerSystemUtilities.sendMessageInternal(DesignerSystemUtilities.java:211)
at com.inductiveautomation.ignition.common.script.builtin.SystemUtilities.sendMessage(SystemUtilities.java:817)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error serializing parameters.
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:400)
at org.python.pycode._pyx269.f$0(<input>:4)
at org.python.pycode._pyx269.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error serializing parameters.
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 18 more
Caused by: java.io.NotSerializableException: org.python.core.ReflectedArgs
at java.base/java.io.ObjectOutputStream.writeObject0(Unknown Source)
at java.base/java.io.ObjectOutputStream.writeArray(Unknown Source)
at java.base/java.io.ObjectOutputStream.defaultWriteFields(Unknown Source)
at java.base/java.io.ObjectOutputStream.writeSerialData(Unknown Source)
at java.base/java.io.ObjectOutputStream.writeOrdinaryObject(Unknown Source)
at java.base/java.io.ObjectOutputStream.writeObject(Unknown Source)
at java.base/java.util.concurrent.ConcurrentHashMap.writeObject(Unknown Source)
at java.base/jdk.internal.reflect.GeneratedMethodAccessor279.invoke(Unknown Source)
at java.base/java.io.ObjectStreamClass.invokeWriteObject(Unknown Source)
at com.inductiveautomation.ignition.common.Base64.encodeObject(Base64.java:496)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface$InvokeMessage.setArgs(GatewayInterface.java:1382)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:963)
... 25 more
