Hi everyone,
I have two questions regarding the Ignition gateway network and would appreciate any insights.
- Auditing journal on local and remote gateway:
I’m trying to configure my auditing journal profile to write to both my local and remote gateway. From what I’ve tried, i wanted to achieve this via direct configuration by setting up a remote auditing journal on the local gateway using store and forward. Additionally, I tried to configure the project settings in the Designer to use the remote audit journal. I thought that this setup allows logs to be stored in the local database while also forwarding them to the remote gateway. However, it did not work like i wanted.
- Can someone confirm if there is a way to achieve this through direct configuration?
- Filtering alarm journal profiles by remote gateway:
I have multiple remote gateways, and I want to filter each gateway’s alarms so that they are logged in their respective journal profiles. I attempted to use the Filter Source field by entering the gateway name, but this resulted in no data being received.
Does the Alarm Source refer to the gateway name, or is it refering to the source column from the alarm events table?
If so, what’s the correct way to filter each alarm journal profile to ensure it only logs alarms from its corresponding remote gateway?
Thanks in advance for your help!
