I am encountering this new error,
when I open the Gateway and try to start the gateway,
[color=#FF0040]GATWEWAY: ERROR: Sytem Error 5 has occoured. Acces is Denied[/color]
But actually the Gateway is funning
#2
Please check
Could not upload attachment to ./files/5416_7552e1d4771215c0e99ffc569e1259fd.
i cannot upload the attachment in the forum
“System Error 5” is a windows error, see this knowledge base article support.microsoft.com/kb/555644
Can you start the Ignition Gateway from the Windows Services panel?
Yes,
I can start the service is running
and I work normally
except that the Gateway Control Utility wouldn’t show any thing…but Trying to establish the connection
Sounds to me like you’ve got some permissions issues that are preventing the GCU from working correctly. This likely has to do with the fact that you are running Vista. Try running the GCU under an administrator account. You don’t have to use the GCU at all, however, it is just a convenience.
Yes, running under vista, under administrative account…
its ok…
The same happened in Win7 after an update. Running it as Administrator did the trick!
