Hello, I would like to know if anyone knows if it is possible to generate an automatic report when a tag reaches a certain value. For example, if in a tag I am having a reading of values but the reading drops to 0, a pdf report is generated. I was watching the videos of the course but I couldn’t find how to do it.
thanks
Gateway tag I am assuming?
Make a gateway tag change event on that tag. Then there you can do something like
if not initialChange and event.newValue < 0:
# Make report logic
I think you’ll want this function for your report creation logic
https://docs.inductiveautomation.com/display/DOC79/system.report.executeAndDistribute
One potential issue with this approach I can see is if its possible where it bounces above zero and down over and over, it may make many reports in a short time. If that’s ok with you then nothing wrong with this approach.
