It depends on how you called the shared script. If you are calling it from an event from a component, just pass the event variable to the shared script as a function argument. Then use event.source normally. Otherwise, you’ll need to use getWindow() like:w = system.gui.getWindow('your window name')
component = w.rootContainer.getComponent('your component name')It’ll fail if the window isn’t opened, though, and will randomly select a matching window if multiple instances were opened.
