Get current scope in scripting
Is there a way to easily grab the current scope in scripting?
We have a lot of code that will either execute through normal python, tag event scripts, script console, or perspective scripts. And so we need to identify what scope we are in sometimes to verify how we want to handle a task.
I know that I can try to do things like import the gateway context, or do a perspective print, etc, but is there a more rigid test to see Current scope? (Understanding this will fail in normal python, but we can work around that)
Options :slight_smile:
Perfect! I guess I didnt search hard enough before I asked lol
My preferred option is probably this one
try:
    from com.inductiveautomation.ignition.common.model import ApplicationScope
    scope = ApplicationScope.getGlobalScope()
    if (ApplicationScope.isClient(scope)):
	    print("Client Scope")
    if (ApplicationScope.isDesigner(scope)):
	    print("Designer Scope")
    if (ApplicationScope.isGateway(scope)):
        try:
            system.perspective.print("Perspective Scope")
        except:
	    print("Gateway Scope")
except:
    print("Python Scope")
We’ve got this in a script called env
def isDesigner():
	return ApplicationScope.isDesigner(scope)
def isGateway():
	return ApplicationScope.isGateway(scope)
def isPerspective():
	return ApplicationScope.isGateway(scope) and hasattr(system,'perspective')
def isVision():
	return ApplicationScope.isClient(scope)
Then call it with env.isGateway() etc…
any suggestions on how to make isPerspective() return false when called from a session property? In designer and otherwise?
Do I need to combine this method with SYSTEM_FLAGS?
e.g. when modifying a session property in designer (with change script):
def valueChanged(self, previousValue, currentValue, origin, missedEvents):
	import inspect
	logger = system.util.getLogger(inspect.currentframe().f_code.co_name)
	logger.info('test Property Change Script scope')
	logger.info('isDesigner | {!s}'.format(env.isDesigner()))
	logger.info('isGateway | {!s}'.format(env.isGateway()))
	logger.info('isPerspective | {!s}'.format(env.isPerspective()))
	logger.info('toCode | {}'.format(ApplicationScope.toCode(ApplicationScope.getGlobalScope())))
	logger.info("hasattr('system,'perspective') | {!s}".format(hasattr(system,'perspective')))
	system.perspective.print('test') # returns 'No perspective page attached to this thread'
isDesigner | False
isGateway | True
isPerspective | True
toCode | G
hasattr('system,'perspective') | True
ERROR: 'No perspective page attached to this thread'
Theoretically, something like this should work:
from com.inductiveautomation.ignition.gateway import IgnitionGateway
pageModel = IgnitionGateway.get().moduleManager.resolveClass("com.inductiveautomation.perspective.gateway.model.PageModel")
if pageModel.PAGE.get() is not None:
	# in a page
Subject to change between Ignition versions and Perspective module versions; class names should be considered an implementation detail.
What's the ultimate use case for this kind of introspection?
thank you, I'll give it a shot.
for the moment I'm just using it for context-aware debugging (printing where possible/desired, logging where not). comments/suggestions welcome.
FWIW, I'm fully aware logging alone is the preferred method :slight_smile:
it appears isPresent() is java-specific?
hasattr(pageModel, 'PAGE') returns True for me as well :confused:
PageModel is the class. The PAGE attribute will always be present because it's a ThreadLocal field:
I steered you wrong with isPresent() because it's available in the JDK source code, which is what I was looking at for the class, but it's a package-private method that won't be accessible. The get() method is public: https://docs.oracle.com/en/java/javase/17/docs/api/java.base/java/lang/ThreadLocal.html#get()
So if pageModel.PAGE.get() is not None: would be the equivalent operation and should work.
anyone have success getting custom code/module/component/binding/etc scripting/context tracebacks as well as Ignition does with native logger/console exceptions?
end goal is to never have to specify a logger "name" in system.util.getLogger() - i just want it to know exactly where it is - all the way down to the component/script/function name - from wherever I call it
here's my (super-hacky) variation of @bschroeder's code:
env
# https://forum.inductiveautomation.com/t/get-current-scope-in-scripting/55686/6
def isDesigner():
def isGateway():
	# https://forum.inductiveautomation.com/t/get-current-scope-in-scripting/55686/8
	# https://forum.inductiveautomation.com/t/get-current-scope-in-scripting/55686/11
	try:
		return ApplicationScope.isGateway(scope) and hasattr(system,'perspective') and pageModel.PAGE.get() is not None
	except: return False
def isPerspectiveAsync():
	try:
		return ApplicationScope.isGateway(scope) and hasattr(system,'perspective') and pageModel.PAGE.get() is None
def isVision():
def getScopeCode():
	return ApplicationScope.toCode(scope)
class util:
	class getLogger:
EXAMPLE:
import inspect
logger = env.util.getLogger('{!s}.{!s}.{!s}'.format(self.name, __name__,inspect.currentframe().f_code.co_name))
try:
	#code here
	logger.info('message')
except Exception as e: logger.info(e)
		def __init__(self, name):
			self.name = name
		def __getattr__(self, name):
			def overload(message=''):
				string = "{} {} - {}".format(name.upper(), self.name, message)
				if isPerspective(): system.perspective.print(string)
				elif isGateway():
					logger = system.util.getLogger(self.name)
					eval('logger.{}'.format(name))(message)
				elif isDesigner() or isVision(): print(string)
			return overload
Basically, no, there's no great way to do so at the moment.
I filed a ticket a few months ago to make sure that we're adding context where we have it, probably via the __file__ or __name__ or something standard variables.
thanks! at least now I know I can stop trying for a while and just watch the release notes
Will this help distinguish between a proper Perspective session (ie: button on a Perspective View calling a function) and a function being called from a Perspective session but via an asynchronous thread. ?
The asynchronous thread will not have the thread local for the page.
Yep perfect, I've run a few tests and it is working much better with that in now.
There are a number of topics about this, with this being the only topic that works to distinguish between gateway and perspective :slight_smile: thanks @paul-griffith and @hunterdg
I've incorporated this into @Kyle_Chase 's script from this topic:
try:
	isGateway = True
except ImportError:
	isGateway = False
def getScope():
	if ApplicationScope.isClient(scope):
		return "vision"
	elif ApplicationScope.isDesigner(scope):
		return "designer"
	elif ApplicationScope.isGateway(scope):
			return "perspective"
		return "gateway"
	else:
		raise ValueError("Could not resolve execution scope!")
Edit:
This is simpler from Can I tell what scope a script is running from? - #9 by Michael_Lindon
def getScope():
		return "c" # vision client
		return "d" # designer
		try:
			system.perspective.getProjectInfo()
			return "p"
		except:
			return "g"
	return "u" # unknown
credit to @paul-griffith above for sure.
FWIW this breaks in perspective session startup scripts as page isn’t initialized yet (and it’s asynchronous as discussed up a few posts). I added anisPerspectiveStartup() function as well. Probably should’ve called it isPerspectiveAsync().
This might be another candidate for a wiki-style post as we refine/consolidate.
Can you share this function?
