Get Default Scripting Project
Is it possible to get the default scripting project through the SDK?
Sure, with a GatewayContext you can do:
context.getSystemProperties().getGatewayScriptingProject()
I actually found something similar about 2 seconds before you commented this, I didnt realize there was a search bar in the java docs!
Will that reliably return the same as this?
com.inductiveautomation.ignition.common.script.ScriptContext#defaultProject()
No, they aren’t the same thing. The call from ScriptContext will often be the name of the project currently executing something.
