Get Difference value from dataset
Hi , I have a dataset with below mentioned columns
|t_stamp|running|starting|stop|stopping|
|12:00:00 AM|2026686.859|0|604281.2019|0|
|12:04:48 AM|2027128.76|0|604414.1515|0|
|12:09:36 AM|2027569.067|0|604545.232|0|
|12:14:24 AM|2028008.825|0|604675.712|0|
|12:19:12 AM|2028451.945|0|604806.4073|0|
|12:24:00 AM|2028898.808|0|604938.972|0|
|12:28:48 AM|2029341.828|0|605073.8736|0|
|12:33:36 AM|2029784.787|0|605209.7999|0|
|12:38:24 AM|2030227.914|0|605342.7043|0|
Image for your reference
I need to subtract the first row and second row and get the difference and store the value in new dataset with 2nd row timestamp column. Like wise i need to continue for 2nd row with 3rd row and upto last row
how to do this? can anyone please help me out
The use of PyDataSets makes it easier.
sampleHeaders = ['t_stamp','running','starting','stop','stopping']
sampleData = [['12:00:00 AM', 2026686.859, 0, 604281.2019,0],
        ['12:04:48 AM', 2027128.760, 0, 604414.1515,0],
        ['12:09:36 AM', 2027569.067, 0, 604545.232, 0],
        ['12:14:24 AM', 2028008.825, 0, 604675.712, 0],
        ['12:19:12 AM', 2028451.945, 0, 604806.4073, 0],
        ['12:24:00 AM', 2028898.808, 0, 604938.972, 0],
        ['12:28:48 AM', 2029341.828, 0, 605073.8736, 0],
        ['12:33:36 AM', 2029784.787, 0, 605209.7999, 0],
        ['12:38:24 AM', 2030227.914, 0, 605342.7043, 0],
sampleDataset = system.dataset.toDataSet(sampleHeaders, sampleData)
# PyDataSets lets us easily slice and iterate in a pythonic way.
dataIn = system.dataset.toPyDataSet(sampleDataset)
# Initialize values for creating the output dataset
colNames = list(dataIn.getColumnNames())
data = []
# zip() lets us iterate over multiple objects at the same time.
# We just happen to use the same PyDataSet starting at the next row.
for prevRow, row in zip(dataIn, dataIn[1:]):
	newRow = [row['t_stamp']]
	# iterate over the remaining columns to get differences.
	for col in colNames[1:]:
		newRow.append(row[col] - prevRow[col])
	data.append(newRow)
dataOut = system.dataset.toDataSet(colNames, data)
dataIn and dataOut:
row | t_stamp     | running     | starting | stop        | stopping
0   | 12:00:00 AM | 2026686.859 | 0        | 604281.2019 | 0
1   | 12:04:48 AM | 2027128.76  | 0        | 604414.1515 | 0
2   | 12:09:36 AM | 2027569.067 | 0        | 604545.232  | 0
3   | 12:14:24 AM | 2028008.825 | 0        | 604675.712  | 0
4   | 12:19:12 AM | 2028451.945 | 0        | 604806.4073 | 0
5   | 12:24:00 AM | 2028898.808 | 0        | 604938.972  | 0
6   | 12:28:48 AM | 2029341.828 | 0        | 605073.8736 | 0
7   | 12:33:36 AM | 2029784.787 | 0        | 605209.7999 | 0
8   | 12:38:24 AM | 2030227.914 | 0        | 605342.7043 | 0
0   | 12:04:48 AM | 441.901 | 0        | 132.9496 | 0
1   | 12:09:36 AM | 440.307 | 0        | 131.0805 | 0
2   | 12:14:24 AM | 439.758 | 0        | 130.48   | 0
3   | 12:19:12 AM | 443.12  | 0        | 130.6953 | 0
4   | 12:24:00 AM | 446.863 | 0        | 132.5647 | 0
5   | 12:28:48 AM | 443.02  | 0        | 134.9016 | 0
6   | 12:33:36 AM | 442.959 | 0        | 135.9263 | 0
7   | 12:38:24 AM | 443.127 | 0        | 132.9044 | 0
One issue i am using system.tag.queryTagHistory to get the data from database
but for same minute i am getting many rows for different seconds.
I want only one row data for the same minute and do the difference calucaltion
Is there any possibility to handle that in your script?
Post some sample data (CSV is fine) and I'll see what can be done.
Thanks i have attached it
sampleData.csv (10.9 KB)
When you use Excel to save your csv, please format the t_stamp column to have the date. Saves me having to add them...
dataIn = system.dataset.toPyDataSet(sampleData)
# Sort the items into a dictionary. Key keys are the t_stamps truncated to the minute
dataDict = {}
for row in dataIn:
	# Get the timestamp value and set the seconds to 0
	t_stamp = row['t_stamp']
	t_stamp.setSeconds(0)
	# Check if the t_stamp exists.
	if t_stamp not in dataDict.keys():
		# Make an entry if it doesn't
		dataDict[t_stamp] = {}
		# In the nested dictionary, add the column name and it's value-as-a-list
			dataDict[t_stamp][col] = [row[col]]
	else:
		# Otherwise, append the column values into their respective lists.
			dataDict[t_stamp][col].append(row[col])
# Construct dataset
data = []
t_stampList = sorted(dataDict.keys())
for prevT_stamp, t_stamp in zip(t_stampList, t_stampList[1:]):
	newRow = [t_stamp]
		newRow.append(max(dataDict[t_stamp][col]) - max(dataDict[prevT_stamp][col]))
	data.append(newRow)
row | t_stamp                      | Running | starting | stop     | stopping
0   | Wed Jan 25 18:19:00 EST 2023 | 123.5   | 0        | 548.4028 | 0
1   | Wed Jan 25 18:20:00 EST 2023 | 124.25  | 0        | 207.2763 | 0
2   | Wed Jan 25 18:21:00 EST 2023 | 124.25  | 0        | 0.0      | 0
3   | Wed Jan 25 18:22:00 EST 2023 | 124.25  | 0        | 0.0      | 0
4   | Wed Jan 25 18:23:00 EST 2023 | 124.75  | 0        | 0.0      | 0
5   | Wed Jan 25 18:24:00 EST 2023 | 125.0   | 0        | 0.0      | 0
6   | Wed Jan 25 18:25:00 EST 2023 | 124.5   | 0        | 0.0      | 0
7   | Wed Jan 25 18:26:00 EST 2023 | 124.0   | 0        | 0.0      | 0
8   | Wed Jan 25 18:27:00 EST 2023 | 123.0   | 0        | 0.0      | 0
9   | Wed Jan 25 18:28:00 EST 2023 | 77.75   | 0        | 0.0      | 0
Hi @JordanCClark
I have tested your code but i am getting wrong output. I don't know where i am making mistake (for same minutes i am getting difference value and its creating dataset)
I have attached project file also for your reference. can you please correct me where i am doing wrong
test_data.zip (29.0 KB)
Can you clarify this, maybe with an example ?
can you please check my test project i have uploaded.
there will be example dataset will be there
if i use system.tag.queryhistory its returning same minutes many rows with different seconds difference.
But i want to subtract one minute row with another minute row and get the difference value and store it in new dataset
like this
I can't, I don't have access to an ignition installation at the moment.
Victor is on the right track methinks; however, I'll be held up in meetings and such for most of my day.
As @victordcq had mentioned java.util.date does not have a setMillisecond(). However, we do have access to Apache DateUtils. :slight_smile:
from org.apache.commons.lang3.time import DateUtils
for row in dataIn:
	t_stamp = DateUtils.setSeconds(t_stamp, 0)
	t_stamp = DateUtils.setMilliseconds(t_stamp, 0)
you read my deleted message?:stuck_out_tongue:
i deleted it because the to string doesnt look to milis, but actually now im not sure if the to string even happend on the dicts.
i had no time to check so i just deleted it
Yes, yes I did. :wink:
xD if you react to it, next time you should also undelete it. so others can follow
You should probably just edit it to say 'Never mind...' lol
