Get only the value in reading OPC tag
I have a script to read specific value of an OPC tag
currentVal = system.tag.readBlocking(event.source.parent.parent.PID.Meta.TagPath +'/SV')
print currentVal
and it output as:
[[23.0, Good, Thu Aug 31 12:41:11 SGT 2023 (1693456871880)]]
Now I wanna get only the value "23.0" on my array.
I tried this code: (I am using this before using python to get the first value of array)
print currentVal
print currentVal[0][0]
But I am having error:
Caused by: org.python.core.PyException: TypeError: 'com.inductiveautomation.ignition.common.model.values.BasicQualifiedValue' object is unsubscriptable
	... 45 common frames omitted
Anyone encountered this?
Or is there a way to get only the value in the ArrayList?
Thanks and Regards,
Solved!
print currentVal
print currentVal[0].getValue()
Reference:
https://files.inductiveautomation.com/sdk/javadoc/ignition80/8.0.0-beta/com/inductiveautomation/ignition/common/model/values/BasicQualifiedValue.html
This is also discussed in the user manual, which includes examples for accessing each component of the QualifiedValue: system.tag.readBlocking - Ignition User Manual 8.1 - Ignition Documentation
do you have to use .getValue, can't you just use .value?
you can
.value, that is, not .Value. Case matters.
