Anyone have a trick to get rid of the tool tip on the page navigation at the bottom of the 'Report Viewer' while keeping the navigation?
Here's a script that will do it for you:
# Only runs once during initialization from the report viewer's propertyChange event handler
# Note: This won't run in the designer
# ...UNLESS the designer is already in preview mode when the window is opened
if event.propertyName == 'componentRunning':
# Import the JButton class
from javax.swing import JButton
# Recursive function to find all of the JButtons
def removeButtonTooltips(reportViewer):
for component in reportViewer.getComponents():
# When a JButton is found, remove the tooltiptext
if isinstance(component, JButton):
component.toolTipText = None
removeButtonTooltips(component)
# Call the recursive function and pass in the report viewer
removeButtonTooltips(event.source)
It simply finds all of the JButtons within the report viewer component and removes the tooltiptext.
Edit: removed unneeded variable assignment, and changed the function name to make it more intuitive.
