Get role from System/User/RoleString
I’m trying to set a memory tag using the following expression on the system/client/RoleString which does not evaluate correctly.
The RoleString system tag is a list of strings, so I’m not sure how I would need to check the current users role against the system tag.
if ({[System]Client/User/RolesString} like 'Engineer', 1, 0)
I don’t believe this is working because ‘like’ isn’t a function in an expression. If I was use I would use the built in function hasRole(). From here you list the role your looking for, the user, and then the user source.
hasRole("Engineer", {[System]Client/User/Username},"user source")
If your looking at the current user and user source you should also be able to do just:
hasRole("Engineer")
It will return true if the user has the role and false if they don’t.
hasRole() worked perfect, thanks!
Clearing up a minor thing:
like is actually valid in the expression language, but this is not the right use case for it; like would be used if you had a single string and wanted to check its content.
