Get Source of Each Alarm from QueryStatus
I've got this script in the console that gets me what I want, but I don't want to just print it, I want to store it in a list of strings.
#get the list of all acknowledged alarms
alms = system.alarm.queryStatus(state=["ActiveAcked"])
#initialize empty list of sources
sources = []
#active ack'd alarms count is non-zero
if alms is not None:
	#for each alarm, get the source path and add it to the list
	for alm in alms:
		print alm.source
but whenever I try to cast the source path to a string or assign it to a variable I get the error NameError: name 'source' is not defined
sources = []
	for alm in alms:
		sources.append(str(alm.source))
Of course now that I post it here I don't get an error...
This is a classic case for a list comprehension, for what it's worth:
sources = [str(alm.source) for alm in system.alarm.queryStatus(state=["ActiveAcked"])]
Getting better at list comprehension, but I don't always spot it right out of the gate.
How does this handle the null list?
Can queryStatus return null? Most of our functions that return a list are pretty good about returning an empty list if there's no values, not an outright null.
You're right that my implementation wouldn't handle it if it were somehow null.
Great question, not sure but I have that catch in there to make sure if there ever was a null that I'd get an empty list instead. I noticed that a new string array tag had value null, so I just reminded me to check for that.
Since this is a query, is there a way to order the results outside of doing it in python after I have the list? And on that note, how is the order determined?
I ask because there's a button on the screen that stores the current list of Active and Acknowledged alarms and I want to be able to compare that stored list against the active list and I need to know when there's a difference. Right now I'm using
ackdALMs,knownAckdALMs = system.tag.readBlocking(['[default]Alarms/Remote Reset/ackdALMs','[default]Alarms/Remote Reset/ackdALMs_known'])
	return not ackdALMs.value == knownAckdALMs.value
but that may not work if the order is not always the same
