Hello,
I m trying to get the selectedPath on clic on the tree tag browser but not working. is it a bug or i’m doing something wrong.
Hi @lachguerabdallah, shouldn’t it be .selectedPaths?
For example: selectedPath = event.source.selectedPaths.getValueAt(0,0)
hi @matthew.ayre
thanks for answering.
I have made a mistake in the code, but it still does not work, it does nothing and does not give any error!
@lachguerabdallah, instead of using a mouseClicked event you could use a propertyChange event with the following script:
if event.propertyName == "selectedPaths":
print event.newValue.getValueAt(0,0)
...you should use...
Thank you very much, it works perfectly with your solution.
How to right click the tag and copy the tag path in tag tree browser?
any way to do this?
Hi @prasath.t, not sure I’ve never tried. I might get a chance to try later. I’ll let you know if I find anything.
Ok … please let me know
