Get UDT parameters in event script
Hi all, is there a way to access from a 'Values ​​​​​​​​​​​​​​​​​​​​​​Events -- valueChanged) the parameters of the UDT it belongs to?
I tried with:
parameters=system.tag.readBlocking(["[.].parameters"])[0].value
and it prints all the information of my udt, but when I try to access
parameters.get("Parameter[DBNumber]").value
it gives me an error on the type..
I can't test this right now, but I'm pretty sure you can get all the parameters by using the argument tag in the valueChanged definition.
Try using tag["parameters"]["DBNumber"] ?
EDIT: Nevermind I already have an example about this in one of my UDTs. It's for a "qualityChanged" event script but it should behave the same.
Hi Samuel,
thank you very much, now it works correctly
