Hi guys,
I'm trying to get the selected row value but facing the below problem.
Does anyone have any idea what is wrong on my end?
def valueChanged(self, previousValue, currentValue, origin, missedEvents):
if currentValue.value != '' and currentValue.value != -1:
self.view.params.value = self.props.data.getValueAt(currentValue.value, self.props.selection.selectedColumn)
This script was added in selectedRow onchange script.
Thanks,
Priyanka Khandge
How is the data being returned, as a JSON or dataset?
.getValueAt will only work for a dataset
Yes, resolved my problem using the below script:
headers = []
data = []
arrayDataset = self.props.data
for row in arrayDataset:
if not headers:
headers = row.keys()
data.append([val for key,val in row.iteritems()])
dataset = system.dataset.toDataSet(headers,data)
self.view.params.value = dataset.getValueAt(currentValue.value, self.props.selection.selectedColumn)
self.view.params.ID = dataset.getValueAt(currentValue.value, 'ID')
Tip: "value" probably isn't a great name for a view parameter!
Change it before you've used it in too many places.
Probably worth noting that if possible, probably want your data in props to be a dataset. For large amounts of data they do run more efficeintly than a JSON
Or at the very least, avoid converting the data from a list to a dataset just to pull a value out of it!
self.view.params.value = self.props.data["ID"]
Edit: I focused so much on the ID piece I didn't see that you were trying to get a dynamic value based on the selectedColumn value.
self.view.params.value = self.props.data[currentValue.value][self.props.selection.selectedColumn]
What version are you using? Tables provide access to this information in a property already. It might be hidden behind that tooltip.
I think a better solution here is to bind some custom prop with an expression structure binding, and only perform the write to your param within the change script:
# An assumption here: Only one row may be selected at a time
# We actually don't care about the selectedRow part of the value, we just want this binding to
# re-evaluate whenever that value changes, OR when the data changes, OR when the selectedColumn
# changes. After placing this binding, your change script on Table.props.selection.selectedRow
# should ONLY write this custom prop value to the param prop you've set up.
return value.data[0][value.selectedColumn]
