Get Values from Int Array
Hello
is there a way to get the values of a Int array from a Siemens SPS 1515 over the Ignition OPC UA server? We only get the first Value and differented into bits.
What should we change to get the Values itself??
There’s nothing to change. Siemens driver in Ignition doesn’t support arrays… yet…:unamused:
This is from help docu:
“Additionally, array data types can be used with devices that do not support array types, and will instead expose each bit in the value.”
https://docs.inductiveautomation.com/display/DOC79/Array+and+Dataset+Tags
[EDIT:]
I just tried v7.9.6 rc1 and still no support for arrays…
