I’m trying to get the IP address of the machine viewing a web app. I expected this bit of python in the Client startup script to do it:
system.tag.write('[Client]writable', system.net.getIpAddress(), True)
Instead, it gets the IP address of the server/gateway.
I also tried to access it through [System]Client/Network/IPAddress to the same effect.
So, how do I do this?
Edit:
I should add that this is a mobile app, which I think might be part of the issue.
From the guide: [quote]Mobile clients are virtual clients that are launched on the server.[/quote]
So I guess my question is, is there a workaround to still access the ip?
To take another tack, is there any way to embed the client id in the meta data of a mobile module web app?
Okay, one more try, is it possible to bake a string into the URL on a per-client basis?
Thanks pdibenedetto!
For posterity:
Use a URL e.g., localhost:8088/main/system/mobile?project=myProjectName&someParam=foo
“myProjectName” is the name from “myProjectName.jnlp” and “someParam” is a client tag in designer like “[Client]someParam”.
You must upgrade your Gateway to 7.6.3* for this to work (and Java to 7).
