Getting MSSQL database connection error: Cannot create PoolableConnectionFactory
java.sql.SQLException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "No appropriate protocol (protocol is disabled or cipher suites are inappropriate)".)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "No appropriate protocol (protocol is disabled or cipher suites are inappropriate)".
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:1368)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1412)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1058)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:833)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:716)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:841)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
... 12 more
Caused by: javax.net.ssl.SSLHandshakeException: No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
at java.base/sun.security.ssl.HandshakeContext.(Unknown Source)
at java.base/sun.security.ssl.ClientHandshakeContext.(Unknown Source)
at java.base/sun.security.ssl.TransportContext.kickstart(Unknown Source)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1379)
... 20 more
8.1.24 (b2023011208)
Azul Systems, Inc. 11.0.16.1
I would suggest looking at the knowledge base article below. You likely need to upgrade your MSSQL JDBC Driver or update your MSSQL Server instance.
Option 2: Re-enable TLS V1 and TLS V1.1 on the Ignition Gateway
I have upadated java.security file after that which thing i need to do?
That option requires a gateway restart.
I would strongly suggest updating the driver or updating MSSQL Server (if your version doesn't already support TLS 1.2) before resorting to re-enabling TLS 1.0, and TLS 1.1. Modifying the java.security file is generally only recommended as a temporary solution. The changes will not persist through Ignition upgrades and it's less secure.
