I’m needing to set some text in an alarm and planning to use the name of the folder using a relative path to the folder names:
path is:
This just returns me a number, 2 I think, but what I need is the name. I tried to add .name to the path to get the property but this does not work. I’ve looked at what I can find, but cannot seem to find a solution. Am I just not getting it or should I find another solution.
There are likely a few ways to do this, but the relative path will not return a name in the way you are desiring.
For your use-case:
You can likely achieve this with the built-in displayPathOrSource property along with the help of some string functions.
For example, consider a tag called “Test Alarm” located within a folder called “Folder”. If an alarm is added to that tag and a binding is placed on the Label property that contains this expression:
split(toStr({displayPathOrSource}), ":")[3, 0]
The resulting Label property will be: “Folder/Test Alarm” , and from there you can use split() again to return just the string “Folder”. The expression would be:
