Getting selected cell value in Power Table
I am trying to get a value of the cell from a power table to put into a path to open a file, I have the script working if I put it into a Momentary button and get the value from a label, but when I put it into onMouseClick or onDoubleclick Function in Power table component scripting it doesn't work. I think Im not passing the value of the cell into the path.
    serial = value
	folder_path = "A:\\Results\\MY\\Test\\X\\C\\" + serial + "\\" + serial + "_[20241118]"
	def find_html_file(folder_path):
		for file_name in os.listdir(folder_path):
	 	    if file_name.endswith(".html"):
		        return os.path.join(folder_path, file_name)
	return None
	# Find the HTML file
	html_file_path = find_html_file(folder_path)
	print("HTML file path:", html_file_path)
	# Open the HTML file using system.net.openURL
	if html_file_path:
	 	try:
	  	    system.net.openURL("file:///" + html_file_path.replace("\\", "/"))
	 	except Exception as e:
	  	    system.gui.errorBox("Failed to open HTML file: {}".format(str(e)))
	else:
	 	system.gui.warningBox("No HTML file found in the specified folder.")
You are unconditionally returning None at this line, unless you messed up the indentation when you pasted into the forum.
Yeah that solved it, I messed up the indentation while copying into the power table scripting window. Thank you.
