Getting string data from tag path dynamically
I am looking to get part of my path name dynamically into a memory tag:
My path: Area/LSD/Well/tagname
If i use: left({PathToParentFolder},lastIndexOf({PathToParentFolder},"/"))
I can get back : Area/LSD/Well/
Or If i use: left({PathToParentFolder},IndexOf({PathToParentFolder},"/"))
But the one i need is: LSD
i cant use a dedicated number for the index, because the Area name will change and the name length will differ. any one have any ideas how i could accomplish this?
Thank you in advance…
Edit: I am using this in an ‘Expression’ memory tag in a UDT
Have you thought about using split()? Something like:
split({PathToParentFolder},'/')[1,0]
I can’t test it right now but split returns a dataset which I believe would be one column, you want row 1 to get LSD.
Yes, returns one Column named parts.
If you want to only remove the Area part of the path, you can also use the split with a limit, something like
split({PathToParentFolder},'/',2)[1,0]
In this case, row 0 would be Area, and row 1 would be LSD/Well/tagname
Thank you guys… split({PathToParentFolder},’/’)[1,0]
Worked perfect…
