Thanks Ross but that’s not really what i was looking for, I wanted to access the path property of an object not its value.
My goal is to have an object where i can drop a tag on it and a custom variable will populate with the tag path. If i use indirect i will have to change it for each tag and then it wont be dynamic.
The more I looked into it i don’t think its available without using a tag change script which also defeats the purpose.
all you would have to do is copy the tag path and paste it into the custom property that you create on the component, as opposed to dragging the tag. It would still be dynamic.
I am being lazy, i was trying to make it a one step process if possible. I could drag the tag and then copy the path but doing that for 100+ items would suck. I was hoping to find a way to just drop a tag and move on!
I was trying to figure this out the other day as well. I settled on a custom property that I copy the tag path into. Let me know if you figure out a way to do it.
