Getting values from NULLs
I have this Query:
SELECT
	COUNT(x.dwActualNumberOfDoffings) AS 'DoffCount'
	,x.sRecipeName AS 'Denier'
	,SUM(Shift_Weight) AS 'Shift_LBS'
	,SUM(Shift_Length) AS 'Shift_Meters'
FROM
SELECT
,sRecipeName
,CASE
WHEN sRecipeName = '1385 denier' THEN (42000)
WHEN sRecipeName = '1411 Denier' THEN (31500)
WHEN sRecipeName = '1426 Denier' THEN (38000)
WHEN sRecipeName = '1700 Denier' THEN (26000)
ELSE NULL
END 'Shift_Length'
,CASE
WHEN sRecipeName = '1385 denier' THEN (14.2)
WHEN sRecipeName = '1411 Denier' THEN (10.9)
WHEN sRecipeName = '1426 Denier' THEN (13.9)
WHEN sRecipeName = '1700 Denier' THEN (10.8)
ELSE NULL
END 'Shift_Weight'
FROM BitWinder_1_LH
WHERE dwActualNumberOfDoffings >= 1
AND t_stamp BETWEEN '2022-07-01 08:00:00' AND '2022-07-31 20:00:00'
) AS x
GROUP BY x.sRecipeName
And it returns this:
I am trying to have the Columns that have NULL return a value based off a calculation, something like this: (if denier = 1411 then doffcount * 10.8 = shift_lbs) Im just not sure how to input it into the query.
Any help would be great.
Would it be better to fix why you’re getting nulls in the fist place? The leading whitespace in the Denier column’s last two rows gives it away. Unless there is a reason for it.
Yep that would be better, I didnt notice that white space. That much better. I can fix that easy. Thanks alot for the different set of eyes.
