Getting Window Root Container Object from within a Template
Hi all,
From a Template I am looking to have a Script that will need to access a component on the Root Container. Is there any simple way to get the Root Container of the Parent Window to the Template?
I am unsure if
event.source.parent.parent.parent....
would work in this situation, I did give it a little go and couldn't figure out how many I'd need. I have heard things about the:
from javax.swing import SwingUtilities
but I am not that clued in about it.
Any help is appreciated.
Many thanks,
Max.
You can use this from any event handler in the template:
rootContainer = system.gui.getParentWindow(event).rootContainer
The way I use to now the route is go to the property binding
and then navigate through the properties and click the one I need so I kow the route and can use it elsewhere
If the idea is drag, drop, done, this approach won't work generically from within a Vision template script.
It's also possible to use getComponentForPath to get specific components by name
Example:
# Gets a component named textfield that is nested in a root container named "Root Container"
textfield = system.gui.getParentWindow(event).getComponentForPath('Root Container.textfield')
Should have mentioned this is in vision sorry!
Works perfectly thanks!
