I did open a support ticket and this was the final conclusion:
There likely were some changes to the source code that lead to the change in the behavior as a result of adding the Tag Report Tool in 8.1.19.
However, it seems that in both cases the function is/was likely not returning the expected value at any point, even pre-8.1.19.
In general, the getTotalAvailableSize is more intended to be used with the system.tag.query function in general. With .query you can specify a limit (i.e. find the first 10 tags) which returns a continuation point (next tag that would have been checked), which then can be used to continue querying past the limit. system.tag.browse doesn't allow you to pass in a limit parameter, and is just going to return the entirety of the results every time. getTotalAvailableSize in theory would just return the same as getReturnedSize .
Should be noted that the function is also not returning anything particularly useful with system.tag.query as of right now either. The only reference I can find to it in the user manual is this brief snippet here which isn't very explicit, but we'll likely remove that reference as well Scripting Object Reference - Ignition User Manual 8.1 - Ignition Documentation.
In short, It did change as a result of adding the Tag Report Tool in 8.1.19, but likely wasn't working the way you would expect it to or in a particularly useful way before then when used with system.tag.browse.
