Git Version Control Resource.Json Files
So I am working on developing a version control workflow for my company and I had a question I can’t seem to find answers to, at least with my wording.
If my goal is a near complete management of the gateway and projects in Github, is it reasonable to gitignore the resource.json files?
Most of the time the changes seem to be timestamps and such modifying user. I am not sure if that is valuable or if that is just clogging up the commit history.
You absolutely must commit the resource.json file. Without it restoration is not safe, and some of the attributes within it define critical metadata.
This is unfortunately noisy, mostly because we constantly attempt to recalculate the 'last modification signature' and reapply it to the file. In 8.3 we no longer do this - if the signature is not valid, we just leave the file alone and assume you know what you're doing.
But fundamentally an Ignition resource is defined by the presence of a resource.json file inside a folder inside a particular folder structure - if you are missing one of those aspects you don't have an Ignition resource anymore.
More info here:
