Global custom method
In perspective I know I can create a custom method at root and call that in any of my components within that view.
Is it possible to call a custom method to multiple views? or would I have to create that method for each view independently
Sounds like you just want to create a script module. Is there any particular reason it NEEDS to be attached as a custom method on the root?
It does not have to be attached on root. I just know from previous work that it works on root. But I am not sure how to create a global method that I can use across multiple views within a project
In the top left of designer click “Scripting” and then “Project Library”. Right click and select “New Script”, give it a name, for example I will use myTestScript. Make a function that does what you want
def myFunction(your arguments here):
    # your script here
Then, im not sure what you want to trigger this script, but you simply do
import myTestScript
myTestScript.myFunction()
to call it.
If its on a root property change it would look like
import myTestScript
if event.propertyName == 'someProperyName':
Thank you [bkarabinchak.psi] I will give this a try
A small clarification - you actually most likely don’t want to explicitly import the myTestScript - it will be available automatically, and explicitly importing can lead to issues with stale code.
Learn something new everyday
