Quick question. In another post, I was trying to popup a report, populate the report and PRINT the report using a Global Script Timer. That works fine, but I have a question about REFINING it.
Can I RELIABLY print from only one client running out of say 5 total by specifying an ip address in an IF statement??
I have tried it and it SEEMS to work… just not sure why it wasn’t mentioned before and why I was told that I couldn’t LIMIT the script to only ONE client. Is there something I need to know about that would cause problems??
# Get a list of the alarms that have not yet been printed
alarms = fpmi.db.runQuery("SELECT L.AlarmLog_ndx, LEFT(point_path,3) AS line, (SELECT f.ftsheet FROM ftsheet_reference f WHERE f.line=LEFT(L.point_path, 3) AND f.item_name = L.item_name LIMIT 1) as ftsheet, L.item_name, L.state_name, L.active_time, (SELECT R.recipe FROM recipe R WHERE R.line_id=LEFT(L.point_path, 3) AND R.t_stamp< L.active_time ORDER BY R.t_stamp DESC LIMIT 1) as Recipe, (SELECT B.batch_number FROM batches B WHERE B.line_id=LEFT(L.point_path, 3) AND B.t_stamp < L.active_time ORDER BY B.t_stamp DESC LIMIT 1) as Batch FROM alarmlog L WHERE L.printed = 0 AND L.severity = 1 LIMIT 1")
ip = fpmi.net.getIpAddress()
if ip == "10.24.14.112" and len(alarms)>0:
alarm = alarms[0]
id = alarm["AlarmLog_ndx"]
name = alarm["state_name"]
itemname = alarm["item_name"]
activetime = alarm["active_time"]
ftsheet = alarm["ftsheet"]
line = alarm["line"]
recipe = alarm["Recipe"]
batch = alarm["Batch"]
window = "Report"
fpmi.nav.openWindow("Report", {"Alarm" : name, "item_name" : itemname, "ftSheet" : ftsheet, "active_time" : activetime, "line" : line, "recipe" : recipe, "batch" : batch})
def openAndPrint(Report=window):
import fpmi
# pass alarm name in as parameter to report window
def printLater(Report=Report):
import fpmi
window = fpmi.gui.getWindow(Report)
report = window.getRootContainer().getComponent('Report Viewer')
report.print(None, 0)
fpmi.system.invokeLater(printLater, 9000)
fpmi.system.invokeLater(openAndPrint)
def closeAfterPrint(Report=window):
import fpmi
fpmi.nav.closeWindow(Report)
fpmi.system.invokeLater(closeAfterPrint, 11000)
fpmi.db.runPrepStmt("UPDATE alarmlog SET printed=1 WHERE alarmlog_ndx = ?", [id])
With the understanding that the IP address would have to be static, is this a sound IDEA??
Sure its a sound idea, you could also use the hostname if the IP wasn’t static.
This is a perfectly good thing to do, I think the argument you heard before was a somewhat academic point: FactoryPMI can’t guarantee that there is 1 and exactly 1 client running on that machine. There could be two, there could be zero, etc. It is up to you to ensure that there is 1 client running on that computer.
Ok, so with using the hostname, I am issured that it will only print on that machine. As far as OTHER clients running on that machine, i’m not too concerned about that.
import fpmi
import fpmi
I still want to use the invokeLater, but I would also like to make sure that the “Report” window is open before I Print it.
I know that the “Report” window is the ACTIVE window when it opens, so is there ANY way to use app.nav.getCurrentWindow()
from within a Global Script Timer?
I'm trying to create another Global script for STARTUP.
Example: A user logs in. Then I want to run a query to see if this account is secure. If not, I want to open a window. If it is secure, do nothing.
Here is what I have so far
username = fpmi.security.getUsername()
SQquery = fpmi.db.runScalarQuery("SELECT Secure FROM users WHERE username='%s' LIMIT 1"%username)
if len(SQquery)>0:
data = SQquery[0]
z = SQquery["Secure"]
if z !=1:
fpmi.nav.openWindow("SecurityQuestion")
