gMSA for AD/Hybrid User Source Sync
Several Google searches and configuration changes later and I can't seem to figure out how to get a User Source synced to AD using a gMSA.
I already have MSA configured for the Ignition service and is working for all of our SQL connections/transactions and the SMTP connection; however, I can't get it to work with Active Directory.
I get the following java exception in the gateway Logger: "java.lang.Exception: Invalid configuration for directory search: no username/password for search."
Based on the exception, my guess is that this isn't supported since gMSA doesn't use a static password; however, before I move over to a static service account, I figured it wouldn't hurt to ask the community and see if someone has attempted this.
Thank you in advance for your input!
Hey Daniel,
Can you provide a full stack trace of the error you are receiving? Does the gateway user you are using have a static password currently, and does that user have permission to query Active Directory?
Hi Joshua,
Here is the full stack trace:
#################### Stack Trace Start #########################
at com.inductiveautomation.ignition.gateway.authentication.impl.LDAPHelper.search(LDAPHelper.java:348)
at com.inductiveautomation.ignition.gateway.authentication.impl.ADInternalHybridUserSource.getUsers(ADInternalHybridUserSource.java:200)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.doGetUsers(UserSourceWrapper.java:540)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper$UserCacheImpl.doUpdate(UserSourceWrapper.java:269)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper$UserCacheImpl.doUpdate(UserSourceWrapper.java:265)
at com.inductiveautomation.ignition.gateway.authentication.AbstractCache$UpdateTask.run(AbstractCache.java:118)
################# Stack Trace End #############################
The gMSA being used for the Ignition service does have the appropriate permissions to query AD; however, gMSAs by design do not have static passwords. The account's password is handled entirely by AD (which is regularly cycled/reset every 30 days) and security group membership allows the service to query AD for the account's password. Which is why you don't assign a password in the configuration and is probably the reason we are seeing the exception above.
I've successfully synced AD to an Ignition user source with a static service account; however, it would be best if a gMSA could be used.
