Hello,
I'm attempting to use the Google Map component by following the tutorial on Inductive University. I have obtained an API key, and for now I have left it unrestricted(I will restrict if as soon as I get this to work). I entered the api key in the session settings as instructed. I should be seeing a map centered on the default coordinates, but all I get is a blank map.
Can anyone offer any suggestions on how to fix this?
Thanks In Advance.
****** Update ********************
After posting this message, I saved the project without making any further changes. I came back to it about 24 hours later and the map was now working as I expected. What I did not mention in the OP was that I had just registered my API key with Google less that 1 hour before posting. I can't say this for sure, but I suspect that there is a waiting period after obtaining a Google API key before it can be used.
Hope that helps someone else someday.............
