I have a Vision Browser component that is being used to generate a map that is currently blank. The map is generated with HTML. I removed the binding on the Visible property to ensure that wasn't causing any issues, but the map was still not displaying. Looking at the diagnostics for the client, I saw no errors related to the browser component. I also tested using the URL source instead of the HTML and everything was working as expected. I also changed the HTML to display "Hello World" and this displayed without any issues as well. This makes me believe that the issue is with the html that we are supplying it. It may be a dual google MIT maps api licensing issue that I will be looking further into. Not sure how to check if license is still valid. The development was on ignition 7.9
