I’m trying to grab a value from a table like so
groupName = system.db.runPrepQuery("SELECT DISTINCT groupname FROM shipping_stores WHERE store LIKE ? AND chain LIKE ?", [(valueMod), (value2)], 'Sample')
value4 ="There is already '%s' going to chain '%s' in group '%s'." % (valueMod, value2, groupName)
and spit out a string which uses this value.
I cant seem to coerce what looks like a pydataset to a single string value.
Any idea what I’m missing here?
I assume the query returns a single value, right? You can use this to get the element 0,0 in the dataset:
groupName[0][0]
You can use system.db.runScalarQuery() which will return the value located in the first row and column of your resultset. inductiveautomation.com/support/ ... rquery.htm
If you have more than one value in the resultset that you want to use you'll have to loop through the pydataset and pull out the values you want.
I’m trying to write a loop for this like
[code]value1 = event.source.parent.getComponent(‘GroupName1’).text
divertID = event.source.parent.divertID
bool = false
results = system.db.runPrepQuery(“SELECT distinct groupname FROM shipping_stores WHERE divert LIKE ?”, [divertID], ‘Sample’)
for i in results[][]:
if results[i] == value1:
bool = 1
break
if bool == 1:
…:[/code]
Is this a good way to set it up? I’m getting some errors with my syntax
It’d need to be more like this, I think:
for i in results:
if i[0] == value1:
bool = 1
break
In this instance, i is a row in the dataset. The [0] would be the first value in the row.
thanks Jordan,
update:
for i in range(len(results)):
if results[i][0] == value1:
bool = 1
break
It’s a single column dataset.
It works now.
Great, glad you got it working.
