It seems I am missing something as I am sure this is simple. I have a table that I want to get a value from the dataset and store into a memory tag. This is what I currently have:
# Get the dataset from the Table component & Convert to PyDataSet
ds = event.source.parent.getComponent('Table').data # table component name is "Table"
pds = system.dataset.toPyDataSet(ds)
# Grab the second item of the first row
strTag = pds[0][1] # strTag is a memory tag defined as a STRING
When I run this code, I do not get any results, and the Output Console does not show any errors. Can anyone see what I am missing? I tried this same code with the data as a DataSet as well as pyDataSet.
