I have a window that accepts a dataset as a parameter that comes from a parent window. Previously this was calculated by running a query, but there must be a way to get that full row as a dataset. How can I do that?
For instance, I have a table with a bound sql data query, and I want to get the 5th row as it’s own dataset.
Answer for anyone else seeking a solution, what I came up with
def getRow(data, row):
Input table data and row you want to get a dataset from
Args:
data: Dataset, ususally table.data, but works with other datasets as well
row: int, what row do you want?
Returns:
dataset: 1R x MC, where M is the number of columns in the datset
import system.dataset
columns = map(str,data.columnNames)
values = []
for col in data.columnNames:
values.append(data.getValueAt(row, col))
return system.dataset.toDataSet(columns, [values])
Why do I map the str to the data.columnNames? Because system.dataset didn’t like it otherwise. Not sure why. But this works.
data.columnNames is a string array on the Java side, but the system.dataset.toDataSet function requires a list of strings. You could also just list(data.columnNames) to do the appropriate conversion.
You could also write your function with system.dataset.deleteRows
Args:
Returns:
return system.dataset.deleteRows(data, [i for i in xrange(data.rowCount) if i != row])
