Having trouble with a Groov Rio from Opto 22. I'm having trouble connecting to Ignition. I have included the Groov information and Ignition Modbus TCP setup. The status is also connecting, then says disconnected, then cycles through again. Any help would be appreciated. I wonder if I have something wrong with some setting in Ignition. Everything checks out with Modscan. I reached out to Opto 22, and they reviewed it and said everything was configured correctly.
Have you subscribed to at least one address? It is common for Modbus devices to kill connections that are otherwise idle, typically after ten seconds.
Are there any messages in the log files?
Are you running Modscan on the same machine as the gateway?
