New to Ignition perspective
I am using v8.1.31
I am trying to shelve the alarms based on associated data: 'Group' when a button is clicked
I had previously System.alarm.shelve working as my folder Hierarchy allowed me but now all my alarms are spreaded out in multiple folder and has a 'Group' to differentiate between them.
Anyone...I have been searching but no success so far.
def runAction(self, event):
group = alarmEvent.get("Group")
if group == "Group A":
return system.alarm.shelve(path=['?'], timeoutSeconds=60)
I don't know how to retrieve the tag path from here. Please Help. Thanks
props = [("Group", "=", "GroupA")]
state = ["ActiveUnacked", "ActiveAcked"]
alarms = system.alarm.queryStatus(any_properties = props, state = state)
if len(alarms) > 0:
for alarm in alarms:
almPath = str(alarm.source)
system.alarm.shelve(path = almPath, timeoutSeconds = 30)
For the sake of your gateway's health in the future, change your script to pass all the paths to shelve at once, instead of calling shelve repeatedly. This will be dramatically more efficient:
system.alarm.shelve(path = [str(alarm.source) for alarm in alarms], timeoutSeconds = 30)
com.inductiveautomation.ignition.common.script.JythonExecException
File "function:runAction", line 5, in runAction
at com.inductiveautomation.ignition.common.script.builtin.AbstractAlarmUtilities.shelve(AbstractAlarmUtilities.java:125)
at jdk.internal.reflect.GeneratedMethodAccessor89.invoke(Unknown Source)
java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: No paths were provided for the shelving operation.
at org.python.core.Py.JavaError(Py.java:547)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:552)
at org.python.core.PyObject.__call__(PyObject.java:400)
at org.python.pycode._pyx32.runAction$1(<function:runAction>:5)
at org.python.pycode._pyx32.call_function(<function:runAction>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:846)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:828)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:832)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1009)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:897)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:158)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:97)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:74)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException
... 34 more
Caused by: java.lang.IllegalArgumentException
com.inductiveautomation.ignition.common.GenericTransferrableException: No paths were provided for the shelving operation.
... 33 more
Ignition v8.1.31 (b2023081007)
Java: Azul Systems, Inc. 11.0.18
[quote="PGriffith, post:4, topic:82909, full:true"]
When I test this code it throws me this error.
Okay, so bail if the query returns no alarms:
if alarms:
