Grouped objects edits in Vision
In Vision module, editing a grouped object is very cumbersome and you have send back/forward or re arrange components in that group to edit the desired one. So it would be nice if we can can have some option to edit the desired one by drilling down in the group from the project properties like a deep select (Right Click & edit) option which directly select the desired one rather moving back and forth components in that group.
Also will appreciate if someone can suggest any other option if it’s readily available.
Thanks…
i usually select components from the projectbrowser
