Guard Door Animation? (Vision)
Hello Everyone,
I am wondering what everyone uses to animate guard doors being open, closed, faulted, etc. Did you make your own template? Do you use images? This is specific to Vision.
TIA
-William
If you use images, I usually create PNGs, upload them with the image management tool. Then use a separate image for each state with an expression binding to determine the image path.
If you have a lot of doors, then yes create a template with your door "animation" and the expression binding based on a template parameter. Then when you place the template in a project, bind to that template parameter with the data source of the current door state.
