Hello,
I try to embed a video player (h264 compliant) based on vlcj in a vision component.
I would like to modify the “ComponentExample_Client” provided with the SDK.
My start point :
Install VLC for windows : [url]http://www.videolan.org/vlc/index.html[url]
I use vlcj : http://www.capricasoftware.co.uk/vlcj/
I try to embed the following example which work very well in a java application,
into the “ComponentExample_Client” :
* This file is part of VLCJ.
* VLCJ is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* VLCJ is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with VLCJ. If not, see <http://www.gnu.org/licenses/>.
* Copyright 2009, 2010, 2011, 2012 Caprica Software Limited.
import javax.swing.JFrame;
import javax.swing.SwingUtilities;
import uk.co.caprica.vlcj.component.EmbeddedMediaPlayerComponent;
* Minimal quick-start example.
public class Example1 {
private final JFrame frame;
private final EmbeddedMediaPlayerComponent mediaPlayerComponent;
public static void main(String[] args) {
final String mrl = args[0];
SwingUtilities.invokeLater(new Runnable() {
@Override
public void run() {
new Example1().start(mrl);
public Example1() {
mediaPlayerComponent = new EmbeddedMediaPlayerComponent();
frame = new JFrame("vlcj quickstart");
frame.setLocation(50, 50);
frame.setSize(1400, 800);
frame.setContentPane(mediaPlayerComponent);
frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
frame.setVisible(true);
private void start(String mrl) {
mediaPlayerComponent.getMediaPlayer().playMedia(mrl);
To test this example directly in Eclipse, we need to specify the path to the VLC dll as follow :
-Djna.library.path=“C:/Program Files/VideoLAN/VLC”
and to add the followinf jar to the build path : jna-3.4.0.jar, vlcj-2.1.0.jar, platform-3.4.0.jar
Could you please help me to modify the HelloWorldComponent.java
May i override the paintComponent method ?
How to add the jna.library.path and external jar ?
